Is anybody running a 255 Intank Pump and a 255 Inline Pump?
Old Oct 1, 2002 | 10:55 PM
Speeds8erM-1's Avatar
Is anybody using a 255 intank pump with a 255 inline pump? I think that will support everything I need right now. If I were to run a smaller inline pump, would it restrict the intank pump?
Old Oct 3, 2002 | 10:07 PM
Would a Vortech T Rex restrict the 255 intank pump?
Old Oct 13, 2002 | 10:43 PM
Somebody has ran a a big inline pump with a big intank pump.
Old Oct 14, 2002 | 12:21 AM
LPEdave's Avatar
I can't tell - is that a wet kit or a dry kit?
Dave
Old Oct 14, 2002 | 06:39 PM
Yes but why would that matter? I have a Granatelli 255 Intank Pump but I want more fuel.
Old Oct 14, 2002 | 06:56 PM
LPEdave's Avatar
It would matter because if you have a wet kit, it needs *more* fuel, but at the same pressure. If you have a dry kit, it needs *more* fuel, and *higher pressure*. I'd think your single in-tank pump wouldn't have an issue at all, if you have a wet kit. But if you have a dry kit, an in-line booster pump to raise the pressure is usually the solution.
Dave
Old Oct 15, 2002 | 12:20 AM
Thats what I thought. The volume is still going to be a problem spraying a 200 shot or more I think. I want stock pressure with more volume. I dont think the 255 intank pump is going to be enough. It's a different setup than the setup in my signature.
Old Oct 15, 2002 | 12:27 AM
LPEdave's Avatar
Ah. If it were me, I'd be looking for one larger pump, then... Probably what you're hoping not to have to do.
Dave
Old Oct 15, 2002 | 05:25 PM
I dont think they make any bigger and it's a brand new pump that just got put in so I dont want to have to get another one anyway.
HectorM52
Jun 23, 2016 08:42 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Skull Leader
Aug 10, 2002 11:01 AM
dmaastr
9
Jul 1, 2002 02:22 PM
