Spray with 12:1 CR, is it possible?
Old Nov 16, 2002 | 02:07 PM
IgorT.455/406's Avatar
Hey guys. With an LT1 motor running a 242/248 solid roller cam and 12:1 CR ported heads, is it possibe to run a small amount of nitros? Or, is it too much compression for spray. Thanks.
Old Nov 16, 2002 | 03:17 PM
RacinLT1's Avatar
As long as the fuel system can handle it.......spray it. What pistons do you have?
Nitrous isnt compression dependant like boost is......Musi runs 14:1 on some of his Nitrous engines.
I plan on building a 11.5-12:1 355 and will be hitting it heavy.....250 shot or so.
Old Nov 16, 2002 | 03:52 PM
For now, the bottom end will be stock, but I might go the same route as you. A 355 that can spin, with 6" rods and forged pistons.
Old Nov 17, 2002 | 01:31 PM
Dan K's Avatar
A buddy of mine has an 11.8:1 396 and he's sprayed 150-200 on pump gas. I think we're pulling 8 degrees on the 150 shot though!
Old Nov 17, 2002 | 09:30 PM
rskrause's Avatar
Moderator
Igor: if I understand right, you are using stock pistons? If so, be very careful. In any case, you will need race gas with this combo as well as the usual colder lugs and reatrded timing.
Good luck.
Rich Krause
Old Nov 17, 2002 | 10:20 PM
Jason Short's Avatar
Forged pistons or not, I would be pulling some timing. Cold plugs too....
I wouldnt even spray at stock bottom end head/cam car....you are just asking to ruin a head if a piston destroys. I have a stock head here that experienced a piston destruction.....
Jason
Old Nov 18, 2002 | 01:03 PM
No, I don't think I am going to use spray while my pistons are still stock. It "might" happen this winter if I have more money, but if I do, I am going to a new rotation assembly. Either a 355 or a 383 with 6" rods and forged pistons. We will see.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
RX Speed Works
Jul 24, 2015 02:25 PM
