Anyway to test the FPSS
Old Nov 4, 2002 | 02:17 PM
TEAL94Z28's Avatar
Question Anyway to test the FPSS
I took my n20 kit off months ago, I was having problems with the fpss before I took it off, is there anyway to test it before I put it back on the car? I have no clue as to where it is set at now. Thanks
Old Nov 4, 2002 | 02:25 PM
LPEdave's Avatar
There's probably a variety of ways... you could plug it into an air compressor set at the pressure you want, then adjust the FPSS to trigger at that point. You could plug it into your fuel system with a gauge, and watch the pressure drop after the motor's off, and set it to trigger at the pressure you want (would only work for a wet system, I guess).
Dave
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
Aaront810
Aug 29, 2020 09:34 PM
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
