Wondering about the effects of colder spark plugs
Old Oct 25, 2002 | 06:59 PM
LT1Thunder's Avatar
Question Wondering about the effects of colder spark plugs
I was just curious of how the colder spark plugs would effect performance when the nitrous is not being used. Does it make a difference at all or what?
Old Oct 26, 2002 | 03:08 AM
Trans AM 22502's Avatar
I'd like to know this too. I want to spray in the near future but there are a number of things that take priority over that.
1) HIGHLY modified valvetrain
2) Headers, Brake Overhaul
3) Cooling system upgrade
Anyways, anyone who has done a tune-up on our cars before knows its a PITA to reach the plugs. So, with my heads off right now, I was thinking of going with colder plugs to begin with, even though I don't have NOS right now. That way I won't have to pull all that crap for another tune-up.
Old Oct 28, 2002 | 01:01 PM
35thanniv.SS's Avatar
Even though I have an LS1, I haven't seen a perfermance change when l leave the nitrous plugs in when im not spraying. I think it would only affect performance when you have a modified engine.
Old Oct 29, 2002 | 02:04 PM
LT1Thunder's Avatar
Nobody else has any input on this? I want to know cause soon I will be buying the plugs and installing them but I won't be using the nitrous that much until spring breaks and I can get to the track again.
Old Oct 29, 2002 | 02:43 PM
396LT192's Avatar
I have not seen any effect on horsepower by leaving the colder plugs in mine. Worst case, you would be looking at 2-4hp tops I would suspect though...if any.
Old Oct 29, 2002 | 03:08 PM
LT1Thunder's Avatar
Question
Is it possible that the multiple spark ignition could offset the effects of the colder spark?
Old Oct 29, 2002 | 03:13 PM
396LT192's Avatar
I am running an MSD 6AL so I suppose it is possible. It feels the same (SOTP) with or without the ignition box though.
Old Oct 29, 2002 | 03:16 PM
LT1Thunder's Avatar
Thanks for the info, I guess I'll be ok with putting them in soon!
Old Nov 1, 2002 | 10:30 AM
Z28ROC's Avatar
I haven't noticed any negative affects of using colder plugs. I've used TR6s and currently 103s.
Old Nov 1, 2002 | 12:22 PM
MonoxideChild's Avatar
how did you route your lines to spray from the front of your hood?
Friend of mine has the same hood. thanks.
Old Nov 1, 2002 | 07:01 PM
Z28ROC's Avatar
I used a stainless -3an line from the purge valve to a bulkhead fitting that I installed in the hood.
Old Nov 1, 2002 | 09:03 PM
rskrause's Avatar
Moderator
I use the coldest plug to fit my heads that NGK makes. They are an "11" heat ranage, which is 5+ heat ranges colder than stock. Using a Crane ignition box and coil I have had no problems. I wonder if they would foul with a stock ignition though.
Rich Krause
Old Nov 2, 2002 | 02:10 PM
LT1Thunder's Avatar
I didn't think that anyone was running plugs that cold! However, I will have a Mallory ignition installed real soon, so I would imagine that I will have no problems at all.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
