Gettin' cold up here...
... in Meechigan, soon no more racing.
Question... what needs to be done with the bottle, anything special or can it just be left in the car through the frozen months? Thanks and thanks for the tips in the past!
I fully believe that Redbird is more consistant on the squeeze than off.
If redbird's being driven, I'd take the bottle out. No reason to have a large heavy object sitting back there, potentially to get loose in an accident. I think I'd also disconnect the heater and opener, in case you get a short or something.
Or move to California
Dave
Dave
Hink,
Leaving the bottle in weather wise would be a no issue..... But then again no reason to leave it in unless you live in a 10sq. ft apartment with no storage.
BTW, I'm a firm believer that Nitrous cars (so long as you can hook consistently) can be more consostent then an NA application.
KT... being a budget/getto racecar, I finally decided to do it before the BIG M7 here in MI. I have contemplated it all summer and finally did it. I HOLED my two front shocks that have drag launch springs around them. Result?? Redbird now carries the front tires 4-7 feet about 3 inches high! This is N/A or on a 50 hit!! Only problem was they were $95 AGX's!!
LPE... moving to Cal?? WISH I could!!
HInk
HInk
WobblySausage
Oct 7, 2015 02:44 PM
