HELP with nitrous wiring on LT1
Old Nov 9, 2002 | 11:50 PM
KillinFormula's Avatar
Here is what i have NX wet kit, WOT switch, MSD rpm window switch, and a toggle switch or master switch (what ever tou want to call it)
here is how i have everything wired, some guy told me to do it and it doesnt work.
relay with 4 wires from it:
1) red- 12 v pos
2) black- ground
3)orange- goes to silinoids, i know they are right because a professional did it.
4) blue-which i have going to the WOT switch
relay----WOT------Master switch (center prong)
master switch has 3 prongs
1) ground wire coming off of it
middle) WOT switch wire
3) this is where it gets tricky, my RPM switch is hooked to it here is how it hooks up
ground-----(black wire) MSD (red wire)-----12v pos
(and 2 more wires from it)
master switch-----(yellow) MSD (white)----- green wire from coil.
well i need help this isnt working.
Old Nov 10, 2002 | 08:02 AM
MichiganSkip's Avatar
I have a schematic diagram for how I hooked my dry kit up. Would you be interested in looking at it?
Skip
Old Nov 10, 2002 | 05:22 PM
yeah i woudnt mind ooking at it at all, i am in need of ne thing that may help even the slightest bit.
alphaauto
Jan 23, 2015 07:42 AM
Jrlt1
Jan 3, 2015 07:38 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
