*HELP* how to install MSD rpm window switch
Old Oct 26, 2002 | 06:44 PM
KillinFormula's Avatar
ok i have only the 8956 msd window rpm sctivation switch.
i am a 96 lt1 and need to know which wires go to where!
there are 4 wires that tap into or go on something.
1) red wire- where does it go
2)black wire- where does it go
3)orange wire- where does it go
4)white wire where does it go
i have searched all the sites i could find. and havent found a good wiring diagram. so if you could just tell me how you did yours i would be very appreciative.
remember i do not have an msd ignition.
Old Oct 27, 2002 | 12:53 AM
XKnightRider's Avatar
Red- 12V source, usually switched like to your main N20 activation switch.
White goes to your tach terminal on the Computer wire harness
Black goes to ground
Yellow/Orange is the activated lead, if you are using a Fuel pressure safety switch this would go to one side of the FPSS. If you are not using one then it would go the the relay ground. THe window switch completes the ground path thus letting the relay complete it's circuit and you are on the juice
Make sense? If not I could fax you a diagram if you have a fax...or maybe I could post it on my site.
Old Oct 28, 2002 | 02:59 PM
i dont have a fax, but would appreciate it if you could load up a good wiring diagram.
i have an NX wet Kit with a WOT switch, MSd WS, and the main switch to turn it on.
the main switch has 2 wires coming off of it, 1 going to the WOT switch and the other to a positve source. then from the other prong on the WOt switch i have a wire going to my blue wire in my relay. on the relay i have a black for ground which is connected to my body at a nother ground source, a red that goes to my positive source, and the rest are wires going to the silinoids.
i bought my system used so he just ripped it off and it was all still wired but i bought a MSD WS afterwords. so if you know how to set it up with that set up, i would be very grateful.
Old Nov 3, 2002 | 05:02 PM
volZfrk's Avatar
Which wire on the computer is the tach signal on 94 Z?
Old Nov 3, 2002 | 07:14 PM
Still need help with how to install a MSD window switch for an LT1.
my set up again is
relay- black- ground
red- 12v pos
blue- WOT switch-toggle switch-12v pos (what do i use the
3rd prong for?)
other wires going to silinoids from relay (forgot their color)
the kit is an NX wet kit, with WOT switch, MSD window switch pn 8956, and a toggle switch.
please help!!!!!!
mr28
Apr 20, 2016 05:44 PM
Collector Car
Jan 5, 2015 10:58 AM
thenewkid
Nov 27, 2014 09:41 AM
mr28
Nov 23, 2014 11:11 AM
