Can the LT4 KM still be used with nitrous?
Old Oct 16, 2002 | 12:57 AM
LT1Thunder's Avatar
I just recently purchased my first ever nitrous kit. It's not hooked up yet and before I do I just want to make sure that I am doing everything perfect to protect my motor. I see a lot of people mentioning things about knock and I was just wondering if a knock module would be a bad thing to hook up or if it would be fine.
Old Oct 16, 2002 | 03:38 PM
gb95zconv's Avatar
I went back to the stocker. I actually see less knock count with the stock km v the lt4 km. Anyway the main thing you need to know is wheather or not you are getting real knock as apposed to false knock. If its real you need to pull timing to correct it or find the cause and correct it before you spray.
Old Oct 17, 2002 | 01:16 PM
FRDnemesis's Avatar
Re: Can the LT4 KM still be used with nitrous?
To be safe; put the stock one back in.
Jeff
Old Oct 17, 2002 | 01:20 PM
LT1Thunder's Avatar
Ok, so how many of you guys running N2O have the stock module in?
Old Oct 17, 2002 | 05:13 PM
drop top steve's Avatar
I use the LT4 KM. You don't want to depend on the KM to pull timing, use a after market ign box with a timing retard. Pull 2 degrees per 50 hp. You also need to have ANY knock issues ironed out before you spray.
Old Oct 17, 2002 | 06:36 PM
George Debski's Avatar
I run a 200 shot on the stock LT1 bottom with the knock module disabled and 93 octane going on 3 years now, but I have a killer fuel system.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
95blkss
Sep 22, 2015 03:18 PM
