What cam is this Lunati????
Old Sep 21, 2004 | 08:46 PM
Bigrob339's Avatar
Hey guys,
I have done some searchen and i still cant find this cam, the lunati b1 cam?? Here the site of the guys camaro that says it a b1. http://www.cardomain.com/memberpage/273500 If you guys could help me that would be great, i am upgrading from a lt1 to ls1 this winter and am wanting a cam and i like how that sounds.
thx rob
LT1 CAMARO FOR SALE EMAIL ME IF INTERESTED!!!!
Old Sep 22, 2004 | 12:49 AM
LSUxBlake's Avatar
Re: What cam is this Lunati????
221/221 .558/.558 114
Old Sep 22, 2004 | 12:31 PM
Bigrob339's Avatar
Why is is called the B1 cam then?I mean i looked at lunati site and it didnt even show a b1 cam? where can i find the b1 cam if thats what it is called?
thx rob
Old Sep 22, 2004 | 12:34 PM
PAGregSS's Avatar
MTI calls it the B1. MTI doesn't sell the B1 anymore.
Old Sep 22, 2004 | 12:41 PM
LSUxBlake's Avatar
Yea not too many people run that cam. I saw more of the T1 which is the same specs on a 112.
Old Sep 22, 2004 | 04:33 PM
Bigrob339's Avatar
what would the difference be between an 221/221 .558/.558 114 and a 221/221 .558/.558 112? i am not very familiar with cam specs. Would the 112 have more of the choppy idle than the 114? because i want it to have a choppy idle so it sounds bad. let me know if you suggest any cams?
thx rob
Old Sep 23, 2004 | 05:08 AM
AL SS590 M6's Avatar
Moderator
thx rob
Narrower lube centerlines move the power up the rpm range, idle choppier, have less vacuum, and are harder to tune.
Old Sep 24, 2004 | 07:58 PM
Bigrob339's Avatar
Alright, i get it now, is there much difference between 114 and 112 lsa? Does the sound change?and does anyone have any sound clips so i can hear some bad a$$ cams?
thx rob
Old Sep 24, 2004 | 10:34 PM
LSUxBlake's Avatar
There is a DRASTIC difference in sound between the 112 and 114 LSA. The 112 will have a much choppier idle, as you are having more overlap. If you are getting a relatively small cam (which it looks like you are) a 114 would sound much closer to a stock idle. For sounds, go to www.ls1sounds.com and look at some of the catbacks and plenty of the cars are running cams in the vids. Good luck with the decision. My recommendation -- a Futral F11, which is what I have. It is a 228/230 .581/.591 112 LSA and it has a GREAT idle (choppy but smooth enough so it doesnt make the whole car shake and rattle) It also drives better than both the hotcam and the 224/224. And it makes a ton of power. If you want, I'll make a vid of mine for you with cutout open and closed, I just dont have anywhere to post it so you'll have to let me send it to you through AIM. Let me know.
Fastbird93
Apr 9, 2016 07:01 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
SpeedJunkee
Jan 14, 2015 05:34 PM
BIGCOWL-IMP
Jul 22, 2002 04:28 PM
