Locktight the rocker arm studs???? ASAP
Old Oct 9, 2004 | 10:27 AM
teke184's Avatar
do i need to locktight the rocker arm studs???
and if i do, how do i get all the oil off of them and out of the bolt holes?
thanks
Old Oct 10, 2004 | 10:11 PM
J0HN D's Avatar
Re: Locktight the rocker arm studs???? ASAP
I didn't locktite mine. I did put teflon paste (sealer) on the intake bolts only, because the porting cuts into the bolt hole, and oil can get pulled around the bolts under high vacuum conditions.
If you're running unported stock heads, I don't think you have to put any type of sealer on any of the rocker arm bolts.
Old Oct 11, 2004 | 06:40 PM
BirchMan98z's Avatar
those bolts are net lash. They will tighten themselves. I WOULD try to clean off as much oil as possible. 22lb/ft should do it for torqueing them down.
Old Oct 12, 2004 | 05:24 AM
AL SS590 M6's Avatar
Moderator
Explain please.
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
JCSWS6
Jul 19, 2015 06:47 PM
94Form
Jul 17, 2015 10:56 PM
