Is this possible?
Old Oct 8, 2004 | 01:43 AM
BlackBird97's Avatar
Is this possible?
An LS1 with a 3200 stall and catback exhaust with slicks running a 12.70? Thats all that is done to it. Is this at all possible it sounds like to me. But I just figured i'd ask you LS1 guys before I said anything. Thanks.
Old Oct 8, 2004 | 04:52 AM
AL SS590 M6's Avatar
Moderator
Re: Is this possible?
Well I had:
Loudmouth
Lid
Yank ST3500 TC
Free mods
And an SSRA
When I ran 12.15 @ 110.8
So a 12.70 is pretty weak.
Old Oct 8, 2004 | 01:07 PM
So does that sound about right?
Old Oct 8, 2004 | 01:21 PM
Timberwolf's Avatar
what year car? that's gonna make some difference too. it will be easier to run those numbers on a 2001-2002 car with the ls6 intake and better exhaust, etc.
My heavy convertible ran 12.89 with the mods in my sig. And it's a 99 with the stock ls1 intake, etc. I don't think it's unreasonable at all to run a 12.70.
(BTW, I think Al's secretly running methanol in his gas tank)
Old Oct 8, 2004 | 06:17 PM
LSUxBlake's Avatar
Totally possible. There is a guy on LS1tech with 3.73's a 4500 stall, and 309 rwhp running 11's on slicks.
Old Oct 8, 2004 | 07:27 PM
Greed4Speed's Avatar
That car has been lightened up too.
Old Oct 8, 2004 | 07:55 PM
DanBUCF's Avatar
My dad's full weight 2000 A4 convertible ran 13.1 with only a lid.
Put a converter, exhaust, and some slicks on that car, and it'll easily do 12.70
So yes, its entirely possible.
Old Oct 8, 2004 | 08:20 PM
96SFLZ's Avatar
As said, it's easily possible...not saying that every LS1 F-body with those mods would run easy 12s...but plenty of them could.
A high stall and sticky tires will do wonders for autos.
Old Oct 8, 2004 | 08:21 PM
V6toZ28's Avatar
Ran 12.52 with essentially the same set up ...only difference a cut out and a FIPK ... full weight.
Old Oct 9, 2004 | 12:31 AM
It's a 98, so no LS6 intake or anything else ...completly stock besides stall converter and SLP quad exhaust, no weight reduction or anything. This is in IL too. Union Grove raceway.
Old Oct 9, 2004 | 12:33 AM
94ZRiCeKiLr's Avatar
a stalled auto LS1 is NO JOKE. even with everything else stock, they will run hard.
check sig....12.teens @ 110-111 all day on drag radials with litte more than a full exhaust, a lid, converter, and gears. and that was on the old converter. i'm hoping for an 11 second motor pass this fall before i crack open the blue bottle.
Old Oct 9, 2004 | 01:40 AM
WiseguyZ28's Avatar
that sounds close to where it should be. What do all u think i could run with the mods in my sig on stock tires? how bout if i add some 10.5 inch rears and 8.5 in. fronts?
Old Oct 9, 2004 | 06:33 PM
on stock tires, you could run in the 12s if the track is prepped ok. on slicks you should definitely go around 12.70-12.80.
Old Oct 9, 2004 | 07:02 PM
psychocabbage's Avatar
I think its totally possible.. I have seen straight off the showroom floor 2002 with paper plates and a set of giant slicks get a 12.5..
