Canaries under the hood at cold start
Old Sep 14, 2004 | 01:28 PM
mark896's Avatar
Angry Canaries under the hood at cold start
It's not like a flock of them or anything but there are a few. It's only at the first start of the morning and goes away after 10 or 15 minutes. I've replaced both belts and am not sure what else to start on. Any suggestions?
Old Sep 14, 2004 | 02:56 PM
mark896's Avatar
Re: Canaries under the hood at cold start
Originally Posted by robvas
The belt tensioner or another pulley might be making the noise.
Explain to me the definition of "pulley". When I first purchased the car I was having some kind of noise and the dealer (under warranty) replaced the "belt/idler pulley". I don't know what that is. However, there are two "tensioners" under the hood and about 5 or 6 "pulleys" (if I'm using the terms correctly). I guess what really confuses me is the word "idler". I don't know what that means so when someone mentions it I don't know if they mean a simple pulley or an actual tensioner.
I will say that the serpentine tensioner (the top one) has 3 notches on it: does anybody know what these notches means? Where does the little level selector sit at on your car? Where is it supposed to sit at?
Old Sep 14, 2004 | 04:04 PM
96Chameleon's Avatar
Mine does the same thing. Although I notice it is only when the AC is on. It's been doing it for about 4 months. Now it makes a grinding noise for a few seconds then goes away.
I am going to replace the belt tensioner next week. (along with a dynaspark, some hoses, electric waterpump).
Old Sep 15, 2004 | 05:03 AM
AL SS590 M6's Avatar
Moderator
There is a pulley on every accessory and on the tensioner. The tensioner unit consists of a spring loaded tensioner and a pulley. If you had the recall done all of that is new. It's probably your alternator bearings. Very common in GM products. Myself, if it goes away quickly then I'd ignore it till it gets worse.
Old Sep 15, 2004 | 11:26 AM
mark896's Avatar
Thumbs up Re: Canaries under the hood at cold start
Thanks Al, that it explains it.
Old Mar 16, 2005 | 10:06 AM
I know this is old, but mine turned out to be the crank shaft balancer... the rubber had torn and seperated.
Old Mar 17, 2005 | 11:18 AM
rncotton's Avatar
My 2001 T/A does it. Funny thing is that I did a "turkey baster flush" of the power steering fluid, and the noise went away for a few days. But it came back.
Old Mar 17, 2005 | 12:50 PM
respectirocz's Avatar
i'm not usually in ls1 forums but i got bored
heres my two cents
every accessory has a pulley
your crank, waterpump, alternator, a/c and power steering, (and smog pump for me) all have pulleys
on a serpentine belt set up u have some sort of belt tensioner, it does what it says, it puts tension on the belt
the idler is like a pulley, that does not run any accessory, and does not move to adjust the tension on the belt
hence all it does is idle, it is an idler
make sense?
Old Mar 17, 2005 | 08:54 PM
mark896's Avatar
It's definitely something on the front of the engine and it's gradually getting worse. I've replaced both belts and when I get back to the states in May, maybe I'll do the a/c tensioner. I hear it when the a/c's on.
Stupid problem to have.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
94Form
Feb 10, 2015 11:23 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
