Lunati vs hotcam vs custom grind
Old Sep 14, 2004 | 05:31 AM
SSinfull's Avatar
I just ordered a lid, maf, TB LS6 intake, headers, y-pipe, Diablo programer
Now I gotta decide on a cam....
I have no clue what is best for my setup!?!?!
Whats gonna give me the best bang!!!!!!!!!!!!!!!!!!!????????????????
Old Sep 14, 2004 | 11:50 AM
teke184's Avatar
Re: Lunati vs hotcam vs custom grind
first off...return the maf and the programmer
maf is worthless and causes more problems during tuning
the programmer wont be very effective after installing the cam. you can just get a basic mail order tune for $250 or a dyno tune for probably $300
any of the cams in the 224* range on stock heads are good for 380-400 hp with bolt ons and tune
Old Sep 14, 2004 | 12:36 PM
DANOZ28's Avatar
you must have a great life if you can afford 3 muscle cars! if i had your doe i would either drop in a crate ls6 (aprox $5200.) or port stock heads & cam. you could also port some ls6 heads. if you add a cam remember you have to get better springs. i think a great mild cam would be the stock ls6 (z06) 550lift,218 intake,204 exhaust dur. only costs about $220. i know lunati has just come out with a hollow cam/lighter weight. don't know details but sounds good.
Old Sep 14, 2004 | 01:00 PM
SSCamaro99_3's Avatar
Custom Cam (done by a good person) > Lunati > Hotcam. Do not buy an LS6 crate motor. For that money you have some options.
Old Sep 14, 2004 | 06:16 PM
SSpdDmon's Avatar
224/224 .581/.581 114LSA + Springs/Pushrods + Dyno Tune - Returned Programmer - Returned MAF = What I would do if your car is an auto.
224/224 .581/.581 112LSA + Springs/Pushrods - Returned MAF + Find someone with wideband O2 sensor and tune with Diablo = What I would do if your car is a 6spd.
Given the quircks of the auto trannies, I wouldn't feel comfortable trying to tune the car myself with the Predator.
Old Sep 14, 2004 | 06:51 PM
Greed4Speed's Avatar
The Crane programmer has some tables set up for various grinds of their cams, and you can fine tune it. You can get the same thing from vinci hi-performance. Get one of their cams and tuner, you're good to go.
Or, go to a local shop thats good w/LS1s. Take there recommendation on cam and have them tune it.
I agree, return that MAF and diablo.
Old Sep 14, 2004 | 07:34 PM
SSinfull's Avatar
Thanks for all the tips!
I cancelled the order on the MAF... Only reason I kept the Diablo is because I can easily wipe out any changes I made to the puter...
I Updated my sig but its an M6
Old Sep 15, 2004 | 04:53 AM
AL SS590 M6's Avatar
Moderator
Every body that dis's the Diablo apparently doesn't know the full capabilities. I got one because even after a custom tune (for free from the vendor) I still have a tool to fine tune shift points, fan temps, and on and on. It's also a live scanner and I can read and reset codes not only on the car that it's locked to but most any OBD II GM car that I hook it to. Like our 03 GMC truck.
yeah a good dyno tune is the best, but what if you want to tweak again later? Well you go back and pay some more.
A Predator is a great mid level hobbiest tuning tool.
Old Sep 15, 2004 | 02:12 PM
Thats why I mentioned the Crane. It comes with several tunes in it, then you can fine tune from there.
95chwagon
Oct 16, 2015 12:24 PM
Bxlt1
Sep 29, 2015 03:18 PM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
