ls1 to ls6
Old Sep 8, 2004 | 09:31 PM
safariman's Avatar
ls1 to ls6
i just bought an 01 ss and i was wondering if switching the engine over to an ls6 was possible and what i would nee or would i just have to buy the whole ls6 engine. thanx.
Old Sep 8, 2004 | 10:08 PM
Knowklew's Avatar
Re: ls1 to ls6
its mainly cam, and intake along with all the supporting provisions.
Old Sep 8, 2004 | 10:16 PM
Antz97ZNJ's Avatar
Re: ls1 to ls6
Your better off just modding your LS1
Old Sep 9, 2004 | 04:50 AM
BirchMan98z's Avatar
Re: ls1 to ls6
stripped ls-6 (no intake, no wire harness, no pulleys, no exhaust manifolds etc) is around $5500. Production ls-6 engine is around $8800. Hell, you're better off just buying the ls-6 heads and cam... or a good set of heads and an aftermarket cam. Way better power increases taking that route than trying to convert an ls1 to an ls6.
Old Sep 9, 2004 | 05:15 AM
AL SS590 M6's Avatar
Moderator
Re: ls1 to ls6
Amen
Old Sep 9, 2004 | 08:47 PM
safariman's Avatar
Re: ls1 to ls6
thats what i figured. if it was gonna be too expensive i was just gonna wait and get some ls2 heads and ****. but thanks for the feedback.
Old Sep 9, 2004 | 08:52 PM
Greed4Speed's Avatar
Re: ls1 to ls6
Aren't LS2 heads pretty much LS6 heads?
Old Sep 9, 2004 | 08:58 PM
safariman's Avatar
Re: ls1 to ls6
pretty much w/ bigger ports and lower comp.
Old Sep 9, 2004 | 09:07 PM
ssoulcainls6's Avatar
Re: ls1 to ls6
LS6 blocks are different than LS1 blocks... they can substain high power better, bay to bay breathing is better, they rev up a little quicker. the tolerences on a LS6 are better thus permitting more power (rings seal better and keep up with compression better) other than that theyre the same...personally if i was gunna do anything other than LS1 mods id go all out and get a C5R block and build like hell. thats one baaaad b*tch. siemesed bores can be bored out like hell and is over all stronger.
Old Sep 9, 2004 | 09:31 PM
LT-14me's Avatar
Re: ls1 to ls6
you want an ls6? just do heads, cam and intake and your done. Or if your luck you can find a junked f-bod with an ls6 block. But other then that i would try gm partsdirect.com they supposedly can give you an ls6 motor for 5k and with rebates it will be down to 3. But i would personally just go to a speed shop and get the 6.0 block and modd that. Could be a hell of alot better then the ls6. and as stated the C5R motor is a beast of 427 cubic inches!
Old Sep 9, 2004 | 11:25 PM
BandDirector Blk98ZM6's Avatar
Re: ls1 to ls6
WHAT REBATES?! I just paid $5300 for a new ls6 longblock to replace my knocking ls1 and I haven't heard anything about rebates. If you know how I can get a $2000 rebate, please let me know.
Old Sep 10, 2004 | 12:53 AM
TrackMagicWS6's Avatar
Re: ls1 to ls6
seriously? they have rebates on LS6 engines? info plea se!
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
