Any install tips
Old Oct 5, 2004 | 12:26 AM
Drew778/94Z's Avatar
Any install tips
For Meziere electric water pump, ended up getting one after all
Al, do you have any tips, already gutted the stock T-stat
Old Oct 5, 2004 | 05:03 AM
AL SS590 M6's Avatar
Moderator
Re: Any install tips
This is a very easy install. LS1howto.com has a good write up. The thing that gets glossed over is the fact that it uses a standard sbc thermostat and it's installed in the opposite water port. The pump will come with the upper hose nipple installed. You'll need to remove the nipple and drill 1 or 2 threesixteenths inch holes in the base of the stat for water to flow thru when the stat isn't opened then install it in the upper port and reinstall the nipple.
There are many ways to wire it and I chose to use a relay and fire it with the fuel pump relay trigger wire. That has the pump only on when the fuel pump is on ie. when the motor is running. I didn't want it running with just the key on because of possible battery cunsumption problems when programming.
Old Oct 5, 2004 | 06:21 AM
teke184's Avatar
finally some people are buying these.
let us know how the install goes and if there was any noticable gains.
Nov 18, 2023 07:21 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 09:07 AM
Zomie
Sep 2, 2002 09:01 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
