do you have to upgrade the trans filter when using the deep trans pan for the LS1's?
Old Oct 10, 2004 | 07:04 PM
zo6vette's Avatar
i have a tci deep transmission pan and i was wondering if you have to upgrade the transmission filter? do you use the stock trans filter one or do you have to use a longer transmission filter with a longer neck due to the larger pan?
Old Oct 10, 2004 | 10:51 PM
Timberwolf's Avatar
Re: do you have to upgrade the trans filter when using the deep trans pan for the LS1's?
fluid level is still the same when full, so the stock filter will be fine.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
