Full bolt on's
Old Oct 17, 2004 | 04:46 PM
Briank8811's Avatar
Full bolt on's
What is a "full bolt on" setup with a LS1 motor. I ask this because i hear some parts are a waste of $ for the small HP gain you get. How much should "full bolt ons" cost if i do the work myself. I have a 99 SS LS1 with the stock ram air setup. Thanks, Brian Kaiser
Old Oct 17, 2004 | 06:25 PM
teke184's Avatar
Re: Full bolt on's
same basic idea as the lt1. a good thing to start with is the basics...intake, exhaust and handling
lid, LS6 intake, longtube headers, catback or duals, sfc, lca and sway bars if you want better handling in the curves.
Old Oct 17, 2004 | 11:33 PM
Antz97ZNJ's Avatar
Re: Full bolt on's
think you would know more w/ the extensive work you have done to your LT1....There are many bolt ons,alot useless, but the ones that really count are lid, and full exhaust(ie. headers/Y pipe/Catback)
Old Oct 17, 2004 | 11:36 PM
Knowklew's Avatar
Re: Full bolt on's
what do you consider bolt-on?
Old Oct 18, 2004 | 01:32 AM
AL SS590 M6's Avatar
Moderator
Re: Full bolt on's
Anything that doesn't touch motor oil.
EL waterpump
headers
catback
LS2-6-x intake
throttlebody
emissions removal
lid
filter
MAF
cold/ram air
gears
TC high stall
suspension mods
weight removal
AC/power steering removal
free mods !TB cool, EGR bobbit, smooth bellows, descreen MAF
Old Oct 19, 2004 | 12:07 PM
Loony's Avatar
Re: Full bolt on's
But some consider rocker arms a bolt on. Now what?
Old Oct 19, 2004 | 12:29 PM
RS Dragster's Avatar
Re: Full bolt on's
Everything I have
Actually, there's only two things I don't have: MAF (have one, just don't want to install it) and elec. waterpump. Other than that I'm pretty good.
As far as how much it should cost, I think if I considered my power-adder mods along with TC and gears, it ran me about $4000. I did all the work myself, except TC and gear install.
Old Oct 20, 2004 | 03:15 AM
Moderator
Re: Full bolt on's
In the LT1 world that's true. With an LT1 you can just throw a set of rockers on. But not for LS1s. To change ratio on an LS1 rocker you need to change valve springs and pushrods. Now it's no longer a bolt-on motor those are internal mods.
Old Oct 21, 2004 | 02:14 PM
Haskin Z28's Avatar
Re: Full bolt on's
since when can you just throw rockers on an LT1? you have to to change the springs and rods too
Old Oct 22, 2004 | 03:42 AM
Moderator
Re: Full bolt on's
Not! If your changing the cam yes you need new springs. But many hundreds of LT1 owners have just changed from 1.5s to 1.6s without any other changes.
Old Oct 24, 2004 | 12:59 PM
SLPZ28's Avatar
Re: Full bolt on's
Ok I don't know if this will help:
Stock Z28 2002 Dyno #289/291
with SLP lid/K&N Dyno #298/301 cost $500
and SLP MAF
SLP ram air box
SLP Loundmouth Dyno#331/345 cost $399cat-back $1500 Headers/cats
SLP Cats y-pipe
SLP Longtubes
Ported t-body Dyno# ?? cost $100
Comp Cam & Dyno #385/371 cost$1300 including PCM tunning
Comp springs
$500 more on tunning
Strut tower brace and LCA and panhard bar I got used for $200(BMR)
Hope this helps
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
transam_388
Mar 15, 2015 11:53 AM
cyteone
Feb 7, 2015 06:04 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
