cheapest place for o2's
Old Sep 29, 2004 | 11:33 AM
mc01ta's Avatar
I need a new passenger side front o2 sensor. Where is the cheapest and i mean cheapest for this. I didn't know that o2's were this expensive but some places like denso have them up to $100 for a single 02! Also do i need to replace the other front and the rear? they seem to be fine but the passenger is loose making all kinds of noise and the car is running like crap
Old Sep 29, 2004 | 12:21 PM
Timberwolf's Avatar
Re: cheapest place for o2's
autozone... around $50
Old Sep 29, 2004 | 12:30 PM
hotrod18_69's Avatar
Call Jason Cromer, i just bought two for my LT1 for $36 a piece. Here is his number. 1-850-243-8826
Brad
Old Sep 29, 2004 | 12:35 PM
mook99TA's Avatar
how do you know that your o2's are bad
Old Sep 29, 2004 | 01:14 PM
mc01ta's Avatar
Car runs bad, poor gas mileage, BUT the main thing is the o2 itself is making noise inside like its damaged and its causing a ringing noise through the exhaust. My mechanic said to get a new one. I had my injectors cleaned, new air filter, new fuel filter and top end cleaner and the car still runs like do-doo and has a nice lil miss at idle. My clutch is going which is causing the car to act crappy but it is separate from these symptoms. My spark plug wires look fine and are on good, but I bought new spark plugs hoping that with the new plugs and o2's, the car would be back to normal. Again do i need to replace any of the other o2's if 1 is bad? The car in question is a 2001 Trans Am
Old Sep 29, 2004 | 01:26 PM
Pewter Z's Avatar
Out of curiousity, which top end engine cleaner did you use?
Old Sep 29, 2004 | 01:29 PM
mc01ta's Avatar
the dealer did it, not sure what kind, whatever they carry. Still never answers, but thanks to all that have replied so far.
Old Sep 29, 2004 | 01:48 PM
Pewter Z's Avatar
The reason I asked was because there was some speculation that O2 sensors could be fried by using a top end cleaner like Seafoam, especially if the car has not been brought up to operating temp before the cleaner is applied. A couple of people on this board have reported this issue. If you took the car to a GM Dealer they probably used the GM Top Engine Cleaner stuff which I have heard is %99 the same as Seafoam. I would hope they brought the car up to operating temp. before cleaning.
IMHO I would just replace the one that is rattling for now. (Yes, I budget shop everything ), however keep in mind that both may be bad and only one of them is making a noise. I am not sure if you can 'test' an O2 sensor or not, a quick search on this forum though may yield more info on testing.
Stephen68
Oct 16, 2015 03:50 PM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
