No Speedo, Replaced the VSS, What should I check???
Old May 12, 2005 | 12:01 AM
Need4Camaro's Avatar
What should I check? I'm getting...
- No cruise control
- No Odometer
- No Tripometer
- Most importantly, No Speedometer...
All the other gauges are working just fine and I have no SES... I unplugged the VSS to see if it would set an SES and it DID! So that can't be the problem...
I've replaced the VSS but it was a no go. Anyone know what I should look for now? I'm guessing it maybe a wire under the dash? What color wire should I look for and to where should I follow it?...
Old May 12, 2005 | 09:21 AM
WS Sick's Avatar
Re: No Speedo, Replaced the VSS, What should I check???
The SES light will report if the PCM does not eceive the speedo signal, so the circuit is complete to that point, the PCM then sends the signal to the dashboard. So either the speedo in the gaugecluster is to blame or th ewiring to the PCM from the speedo gauge.
If your car is an auto and still shifting correctly (unless a 93 car) the ECM is seeing it all completely fine, so that would definately tell you that the VSS onthe tranny is working.
Old May 12, 2005 | 09:55 AM
No SES and I'm definately cleaning through the gears quite fine...
Where's the ECM and where's the wires from the Speedometer to the Dash? Also I don't have a ton of wiring and computer experience but I'll do it if I have to... How do I take the PCM apart to check the speedometer wire from that point to the gauges?
Old May 12, 2005 | 10:02 AM
WS Sick's Avatar
The ECM is located under the hood on the pass side fendewell.
The wire will leave the PCM and go through the firewall and travel from there under the dash to the gauge cluster.
I would check at the gauge cluster. I'm not sure what type of signal it would be though , modulated or what. Maybe some of the more knowledgeable people can answer that, also I'm not familiar with the V6 wiring to tell you what color wire to find and in what connector.
Old May 12, 2005 | 03:45 PM
Could this be a bad gauge cluster? All the other gauges besides the speedo, odometer, and tripometer work fine...
blac94Z
Feb 10, 2015 11:02 AM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
