11.45 volts ok for MAF to work properly?
Old Apr 2, 2005 | 03:24 PM
97s10ondubs's Avatar
I did a test because i had a MAF circuit failure code, the pink wire shows 11.45 volts with the key on, the battery showed 12.05 volts at the same time. I do have an electric water pump that probably is drawing some current. Is the MAF going to be able to do its job right with that voltage?
Britbilly
Jan 7, 2015 08:49 PM
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
pete53
Dec 9, 2014 07:31 AM
Eddie Z-28
Sep 4, 2002 11:58 PM
