LT1 A4 to M6 PCM Ques
Old Apr 28, 2005 | 08:07 PM
CODE4LS1's Avatar
Have a couple questions regarding my PCM and "flashing" it to the M6 program. I have a '95 Z28, and I went to my local dealer today and they told me they would not be able to flash my PCM to a M6 program. They said I will have to find someone with the same year Z28 that has a M6 from the factory, so they can copy the files from his PCM and load them into my PCM using a Tech II computer. Are they giving me the run around or will it be this complicated, short of buying LT1 Edit or Tunercat? FWIW, I will not need LT1 Edit until much later when more mods roll in, so I am looking for the cheapest way to get my PCM "flashed" to a M6 program. Thanks in advance for your help, I appreciate it.
Old Apr 28, 2005 | 10:30 PM
redcamaroz28's Avatar
Re: LT1 A4 to M6 PCM Ques
You can send your PCM to pcmforless or ion, or if you have the cable you can load the program yourself like I do.
Ryan
Old Apr 29, 2005 | 08:10 PM
gerard143's Avatar
ha thats bull****. gm can get the info. www.calid.gm.com
Old Apr 30, 2005 | 01:16 AM
CODE4LS1's Avatar
linky no worky....but I am interested to see what the link says in your post.....can you repost it?
Old Apr 30, 2005 | 01:19 AM
gerard143's Avatar
http://calid.gm.com/
that one im sorry
Old Apr 30, 2005 | 09:08 PM
qwk93ta's Avatar
I just did the A4 to m6 swap, I had to drive around on the A4 tune and it was not that bad. The cold idle was really high, but it would settle down when the car warmed up. Your speedo will read about 1/2 the speed you are actually going.
Old Apr 30, 2005 | 09:23 PM
CODE4LS1's Avatar
thx for the info....ill try telling the dealre all they need is his VIN to get the M6 program I need
DirtyDaveW
Dec 1, 2016 05:37 PM
nikolt1
Feb 27, 2015 09:10 PM
willismoons
Feb 14, 2015 08:42 PM
Ricardo
Nov 29, 2014 10:58 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
