Programming Retard for Nitrous/or msd?
Old May 21, 2005 | 10:39 PM
pennys58's Avatar
Exclamation Programming Retard for Nitrous/or msd?
I have the msd retard, but the dyno tuner says it is better to just program it in the computer instead of using the retard box. I also have the digital window switch and am using a wot switch. What do you suggest? Thanks.
John
Old May 22, 2005 | 10:03 PM
pennys58's Avatar
Re: Programming Retard for Nitrous/or msd?
Anyone?
Old May 23, 2005 | 11:06 PM
pennys58's Avatar
ttt...I am going tomorrow to get the car tuned, if anyone has input it will be greatly apreciated.
Old May 24, 2005 | 10:47 AM
Depends...
You don't want to pull timing out of the standard timing table in the PCM. That would cause you to lose performance when running NA. But I believe I saw a thread here in the past two weeks that explained how you could use one of the TCS tables in the PCM to invoke timing retard when you sprayed. Might want to try a "search" and see if you can find the thread. It was a really clever way of handling the problem.
EDIT: Found the link:
http://web.camaross.com/forums/showt...t=timing+spray
Old May 24, 2005 | 11:50 AM
pennys58's Avatar
Thanks Injuneer. That is pretty much what I thought. I read that thread on the the TCS. I also thought that pulling the timing out would decrease performance when running NA. I need to call them to make sure they do this correctly. I definately know that I don't want it to be done half a$$. Atleast the GENX2 is taking them longer than excpected and won't be tuning till the morning. Thanks again for your input, I apreciate it.
John
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
