Freescan for Electrical Faults
My car's electric system puts out about 10-11 volts to the accessories and I was wondering is there any way to check the system using freescan? I know I probably have a bad ground somewhere and I want to avoid checking every electrical connection in the car. I have already checked the battery and alternator and about 10 over connections and I am stuck.
Re: Freescan for Electrical Faults
no underdrive pully. i do have pcmforless. i tested the accessories with a volt meter. they are at about 10.6 volts. i have a brand new optima battery and a high output alternator (140 amps i think). i had both of them tested by an auto shop and they told me they were more than fine. i am thinking it could be a dying fuel pump but i guess it could be a ton of different things. i am just wondering what the likely causes could be? is there any ways to find out with testing everything?
tdigger9899
Sep 7, 2015 10:56 AM
