quick C.A.T.S tuner help
Old Apr 13, 2005 | 12:38 PM
tagz's Avatar
Say i wanna do something simple like just move my shift points up a bit. How do i do it/ There are so many different tables, i'm not sure which one i change, or if it is neccesary to change all of them? The tables i'm refering to is, normal driving shift points, performance shift points, manual shift points, cruise shift points?
Do all have to be changed and work together or do i just change one? if so which one?
Old Apr 13, 2005 | 12:41 PM
sabre81's Avatar
Re: quick C.A.T.S tuner help
normal driving shift points is what you want. Performance is for T/As with the perf switch flipped on. manual i dont think applys, cruise, no idea. i change em all to the same as normal anyway. (i have a camaro so no performance switch for me).
Old Apr 13, 2005 | 12:43 PM
tagz's Avatar
Thanks, didn't even think about that switch being that i have a camaro.
Old Apr 13, 2005 | 12:45 PM
tagz's Avatar
one more thing. does it have to be done by MPH, or can u do it by RPM?
Old Apr 13, 2005 | 02:43 PM
WS Sick's Avatar
As far as I know , in Tuner cat it is done by MPH.
Old Apr 13, 2005 | 04:32 PM
97Z-M6's Avatar
you can do it either way. it has to meet both paramaters.
if you have 1 set to shift at 25 mph at 3000. the pcm has to see both those met if you up the rpm threshold to 4000 it wont shift until it see 25 mph and 4000 rpms.
it has to see both so you can do it either way
Old Apr 14, 2005 | 08:36 AM
WS Sick's Avatar
Which table has the RPM in it?
GREEN3112
Feb 10, 2019 09:19 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
fift5
11
Oct 1, 2015 10:31 AM
NewsBot
Sep 14, 2015 09:20 AM
