extending oxygen sensor wires
Old Apr 12, 2005 | 01:09 PM
ayalam's Avatar
Question extending oxygen sensor wires
I wanted to know has anyone cut and spliced their wires to make them reach the new locations after a longtube header install? will it affect anything? i know that it'll add some resistance but so will extensions. so will it be a bad choice?
Old Apr 12, 2005 | 01:49 PM
Schmidt519's Avatar
Re: extending oxygen sensor wires
Why would be want to do this, save yourself the hassle and buy the extention cables for $30.
Old Apr 12, 2005 | 02:07 PM
ayalam's Avatar
there like 25 a piece and i think i need two or three i have an obd 2 computer so i have 4 sensors. so thats $50 -$75 plus shipping spent on something else like a stut tower brace. i wanted to know because cutting and adding wire is relatively free.
Old Apr 12, 2005 | 02:14 PM
Schmidt519's Avatar
What's your make/model/Yr
Old Apr 12, 2005 | 02:28 PM
ayalam's Avatar
its a 1997 ws6 trans am. i just put a hotcam kit,coated lt headers, electric water pump, taylor ovc wires, cloyes true roller timing chain, heads got rebuilt with a performance valve job. i aslo got the computer tuned by madz28. i spent a lot of money i still need to get the y-pipe made i also have high flow cats (2). i live in california so i want to pass smog i can go to a shop that'll turn their back on the headers since i have all the emissions. i wanted to know if i can save a little.
Old Apr 12, 2005 | 02:29 PM
ayalam's Avatar
thanks for your concern
Old Apr 12, 2005 | 02:39 PM
Schmidt519's Avatar
When I put my Long Tube Headers on, there Jet Hot, they didn't provide the extention cables. When I called them up they recommended three options, use the extra excess wire that is in the harness, not going to happen, buy the extentions, or do what you want to do in splicing the wire and doing it yourself. With that being said, you should be able to splice the wire and do it that way if interested in saving some money, personally though I still would get the extentions and do it right, but thats just my .02
Old Apr 12, 2005 | 03:12 PM
madwolf's Avatar
DO NOT, DO NOT and again DO NOT SPLICE THE O2 WIRES!
Get extensions!
Did I mention not to splice the wires?
Old Apr 12, 2005 | 03:18 PM
ayalam's Avatar
ion i sent u email asking the same question. imma buy them asap. my car isn't running yet have to finish putting on the intake and adjusting the valve lash. but when i get it done i'll send u some pics.
Old Apr 12, 2005 | 03:19 PM
ayalam's Avatar
your wolf reverted back to the old days when afros and big gold chains were in.
Old Apr 12, 2005 | 04:56 PM
Z28barnett's Avatar
FYI,
O2 sensor wires are Stainless Steel, so they can not be soldered with convention lead tin.
You would have to use Silver solder. Or crimp the wires together.
Also the O2 sensors breathe through the gap between the wire and the insulation. So soldering can melt the insulation and cause problems.
Best off with the extension harness or extending the existing wiring, not the part attached to the O2 sensor.
Z28
Old Apr 14, 2005 | 12:22 AM
'88Saleen's Avatar
How many extensions would you need for pacesetter LT's on a '00 LS1?
Old Apr 14, 2005 | 11:16 AM
Schmidt519's Avatar
Should need only two for the front two.
Old Apr 14, 2005 | 11:01 PM
'88Saleen's Avatar
cool, Thats what I thought and what I orderd.
Old Apr 14, 2005 | 11:27 PM
revtime's Avatar
I made my own extensions.
No problems.
Buying extensions is not that expensive and are much easier but I wanted to see if it could be done.....it can.
