diagnostic tool info
Old May 1, 2005 | 09:28 PM
roypenneyz's Avatar
code extracting 1996 and newer gm. old code reader will not work. what do you recemend. tks. rp.
Old May 1, 2005 | 10:28 PM
Re: diagnostic tool info
If all you want to do is pull the diagnostic codes, you can get an OBD-II code reader from Harbor Freight for $40. If you want something more than that, there is an extensive range of hardware and software OBD-II scanners, ranging from $100 to several thousand dollars.
Not knowing what your "old code reader" was, its hard to comment on why it won't work. Was it an OBD-II unit?
Old May 1, 2005 | 10:54 PM
roypenneyz's Avatar
no it is pre 95 ground out reader tks. rp
marlar98
Sep 12, 2018 07:18 AM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:21 PM
CARiD
Sep 7, 2015 08:21 AM
