A way to disable KR at WOT?
Is there a way to disable Knock retard when i go to WOT. And aslo have it add all the timing that has already been pulled, since it normally adds the timing back in slowly? I am using LT1edit.
Re: A way to disable KR at WOT?
Yes.
Just look around for it. Might say KR in PE mode like tunercat but I dont work with LT1edit but assume all the same tables can be found. And the recovery rate is what you need to zero out to make the timing snap back to total advance in the event some KR is pulled.
Aug 7, 2015 08:52 AM
