big cam and vacuum ?
Old Mar 28, 2005 | 09:27 AM
wicked_95z's Avatar
I thought that as the cam got bigger the vacuum goes down. My new cam is a 24x/25x cam and according to datamaster I was pulling ~25 inches of vacuum. Is that normal?
Old Mar 28, 2005 | 12:52 PM
turbo_Z's Avatar
Re: big cam and vacuum ?
Datamaster shows "negative" vacuum via the MAP sensor. You have to subtract the atm pressure from the MAP sensor output to see how much vacuum its pulling. I would expect to see something around 16-19 inHG(MAP sensor readings) with a cam that size in a 383 with over 850 idle rpm.. just a guess.
Old Mar 28, 2005 | 01:05 PM
wicked_95z's Avatar
So if I remember correctly with 25 inches. I would take this reading and subtract the 14.7 atmospheric and end up with around 10.3 in. Is that right?
Old Mar 28, 2005 | 02:22 PM
No, not right. You have to use the same units of measurement ("Hg) for both barometer and MAP.
Standard atmospheric pressure at sea level is 14.7psia = approx. 30"Hg. If your scanner reports MAP as 25"Hg, you would get:
30"Hg barometer - 25"Hg MAP = 5"Hg vacuum
You need to get the "exact" barometer reading from your scanner. That's one of the data fields. Barometric pressure changes with the weather and your altitude above/below sea level.
Obviously 5"Hg vacuum is a bit too low. Were you reading MAP at idle? What idle speed?
Old Mar 28, 2005 | 03:18 PM
wicked_95z's Avatar
Oh okay
Barometric pressure was right around 30.15 and the map sensor reading was 23-25. Idle speed was pretty low, around 5-600 rpm though I have it programmed for 1000 rpm idle. Still working on that one
dfarr67
Apr 10, 2015 07:44 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
