Engine starts, then stalls
Old Mar 30, 2005 | 09:45 AM
briand069's Avatar
Hello,
I hope someone can help. I just finished installing a 94 LT1 in my 69 Camaro. I used tunercat to turn off the VATS system so I don't think it's that. But, what is happening is the engine will start, run for about 5-10 secs and then shut off. I so far have checked fuel pressure and that seems fine. Also, I have not gotten any fault codes. Any suggestions on where to start? Also, when it is running I can increase speed and it doesn't seem to be cutting out. Also, I jumped the fuel pump to keep it running, but it didn't change anything.
Brian
**Edit**
After a little more testing, it appears that the injectors are being turned off. If I spary starting fluid in the intake, I can keep it running. This sounds like a VATS thing but I've already turned it off. Any ideas?
Old Mar 30, 2005 | 09:31 PM
briand069's Avatar
Smile Re: Engine starts, then stalls
Well, after a day off reading other threads, testing just about every sensor/relay in the car, I got it to work. I reprogrammed the 94 Vette PCM with a 94 F body .bin and the car started and is running pretty well. Only thing I can figure is that the programming on the Vette pcm needed the CCM and the F body doesn't? Any one have any insight on this? Oh well, now the fun part of tunning.
i hope that this can help someone else who is doing a engine swap.
Brian
Old Apr 6, 2005 | 06:14 AM
ZPaul2Fresh8's Avatar
Damn, I was gonna say coil
Serioulsly, mine was running for 3-5 secs then cutting out. Turned out, the coil had somehow weakened over the 4 month storage.
She's good to go
Old Apr 6, 2005 | 04:27 PM
WS Sick's Avatar
Glad to hear you guys got these figured out.
DirtyDaveW
Dec 1, 2016 05:37 PM
Amshnock
14
Jan 18, 2015 11:47 AM
David Dorris
Jan 17, 2015 08:10 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
