disabling vats didn't work, how do i do it.
ok, i just installed a remote start on my 95z. it will only work if the key is inserted into the ignition hole. so obvisously its my vats. i used lt1edit and under the function enable drop down menu, i went to "vehicle anti-theft = 4" and turn that from "on" to "off"
but this still didn't work. Vats is still active. is there something else im suppose to do in the pcm?
Re: disabling vats didn't work, how do i do it.
There starter kill function is still enabled, the fuel cut off is what you disabled in the PCM. Shoebox's site has a write up on how to wire in a resistor for the VATs to disable it.
Gtpguy
Jan 26, 2015 04:50 PM
fpete1992
Dec 11, 2014 03:51 PM
