Stock 94 Z28 Auto tunercat bin
Re: Stock 94 Z28 Auto tunercat bin
I reviewed yours. Unforutunately, tables I hadn't even modified were different in it. It wasn't very similar to mine at all for some reason. Thanks though.
dont interchange 94 bins with 95 and newer, 94 trans have a on/off tcc for your lock up in the trans, 95 and newer have pwm tcc apply
your trans will not function correctly if you have the wrong year bin file in it
I have MAF tables from that were modified by PCMforless for a descreened maf but they aren't really much different at all. Only a tenth of a point and only in a few spots.
Originally Posted by Eddie95Z28
I have one from a 95. Should be similar enough to use. Let me know if you want it.
Could you send me your file? I have a 96 z that I just did the OBD1 conversion on, and the tranny is not shifting like it did with PCMforless obd2 tune I had before. The tune we had for my set up was for a M6, so we copied a 94 a4 I think? Tables over and used them in that tune. Now it's just not right.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
