freescan log
Old May 4, 2005 | 03:19 AM
unTAmedLS1's Avatar
freescan log
will someone take a look please I can email it to you just pm or post me your email or email me at southhockey93@aol.com thanks car is running like crap
edit* its also located here
Old May 4, 2005 | 11:22 AM
delancj's Avatar
Re: freescan log
TPS voltage should be .54v at idle. it looks to be .88.
right o2 is reading rich so its leaning the fuel to that side. how old are the injectors?
im no expert but thats a suggestion
Old May 4, 2005 | 12:59 PM
unTAmedLS1's Avatar
Re: freescan log
injectors are brand new
Old May 4, 2005 | 01:12 PM
WS Sick's Avatar
Re: freescan log
I think on average the O2s were looking pretty good, they were reacting back and forth but the right hand column O2 was reacting a little slower.
Do you have a ported MAF or what MAF table are you using, I think the MAF GPS are a little high , Ssomeone plaes correct me if I'm wrong (not sure)
But at a 850 idle my MAF is at 12 with freescan and moves up to 25 after light throttle (maybe 10 to 20 % throttle.) Unless I am looking at it wrong.
Old Jul 2, 2005 | 03:27 AM
unTAmedLS1's Avatar
Re: freescan log
its just a descreened maf and yes it is high so how do i adjust that condieing i think thats why my car is running lean
Old Jul 2, 2005 | 05:27 AM
turbo_Z's Avatar
Re: freescan log
I agree. Thats the only "problem" I noticed as well.
Old Jul 2, 2005 | 05:40 AM
unTAmedLS1's Avatar
Re: freescan log
actually now that i think of it wouldnt that make my car run rich? So if I have all these things causing it to run rich why do the plugs show a lean condition
Old Jul 2, 2005 | 10:27 AM
turbo_Z's Avatar
Re: freescan log
It wouldnt run rich just because of the 20 gps at idle... all depends on how accurate that reading is. If the motor is really needing 20 gps of air to keep up 900 rpm a idle then its gonna be a gas hog but not necessarily run rich or lean.
Try setting the valve lash again to see if that helps any.
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
