scanmaster ?
Old Apr 25, 2005 | 09:56 PM
steves97z28's Avatar
scanmaster ?
could i use a ls1 scanmaster on my 97 Z? i know the lt1 scanmasters wont pull codes cause its for obd1, but the ls1 is for the obd2 so i was wondering if i could use it on my car. it also only plugs in and doesnt have to be wired. any help would be great, thanx.
Old Apr 26, 2005 | 12:44 PM
mike96lt1's Avatar
Re: scanmaster ?
I have a 96 and my LT1 scanmaster works fine its for 94-97 lt1 the only one it wont work on is 93s.
Old Apr 26, 2005 | 12:58 PM
Re: scanmaster ?
but it wont allow you to check and clear codes correct? im gonna order one either way i was just curious to see if this would work since it would do more.
Old Apr 26, 2005 | 01:46 PM
mike96lt1's Avatar
Re: scanmaster ?
I don't think you can clear codes on any car with it but it does have some Preprogrammed trouble codes that it can read from your PCM but it does not read all PCM codes.
Old Apr 27, 2005 | 02:04 PM
Re: scanmaster ?
do you have to splice wires? or does it have a plug like the ls1 snanmaster does?
Old Apr 27, 2005 | 02:20 PM
mike96lt1's Avatar
Re: scanmaster ?
The manual says to splice the wires but I soldered pins on the wire and just plugged it into the ALDL this way I can just pull the wires out when I need to check codes.
Old Apr 27, 2005 | 02:31 PM
Re: scanmaster ?
It will read ALL PCM codes on 94/95 models. It will not read any OBD-II (96/97) trouble codes. It can not clear codes on any year. All other functions will work on 94-97 models.
Some help with what it can and can't do, installing it, interpreting the data, etc.:
http://members.aol.com/InjuneerZZ/ScanMast.htm
Old Apr 28, 2005 | 09:57 AM
mike96lt1's Avatar
Re: scanmaster ?
Injuneer thanks for the write up it helped me understand alot when it comes to tuneing a must read if you get a scanmaster.
Mike
Peytons'z
May 6, 2021 09:25 AM
marlar98
Sep 12, 2018 07:18 AM
marlar98
Sep 19, 2015 07:53 AM
Shon Herron
Mar 18, 2003 12:18 PM
88irocz28
Feb 28, 2003 11:24 PM
