AirBag/ABS INOP HELP (long)
Old May 15, 2005 | 11:12 PM
RedsTA's Avatar
Last week me n a friend were going to install a Jet stage 2 chip. Everything should have worked fine, its an easy install.
Once it was installed the first time, the SES light came on... you could smell gasoline like i was running really rich. Code: 34 MAF/MAP sensor too low.
So i called Jet, they said to make sure the connection to the power is good, so we cut into the power wire, stripped it, and connected 2 in one side, one in the other. Should have worked fine again, and SES light came on with the same code. Each time i started the car it hardly wanted to start unless i gave it a little gas.
So i got pissed and just wanted my car without the chip on it, so we started to take off the pcm connector again and couldnt get it off, so i was going to get something to grap the black connector with and my friend gets the bright idea to pull on the wires to pull it off... Well it did come off, but i think it threw my ABS INOP and Airbag light on... I THINK.
Would this even make sense? I looked at the connector to the pcm that he pulled on and only about half the holes were filled with a copper color. I never looked at this before, but im guessing all of them should be filled? If anyone knows, Its the upper left connector if you pull it out and youre standing on the passenger side of the car.
The other reason i think it might be this is, we had a pretty hard rain the other day, and when i started my car after work and it was sittin in it, the Ebrake light flashed on and off for a second or two and so did another light until i grabbed the ebrake and it stopped flashing.
Any help is appreciated. Thanks in advance.
Rod Bender
Nov 7, 2023 02:30 PM
grabbem88
20
Dec 27, 2015 07:42 PM
Jmlcolorado
Jul 4, 2015 08:31 AM
pologreen97z
May 18, 2015 02:17 PM
jj_burchiel
Mar 21, 2015 12:51 AM
