Need help with code po1629
Old Apr 18, 2005 | 10:00 PM
702camaro's Avatar
Angry Need help with code po1629
hi , i bought my first camaro 4 days ago from the auction and it wont turn over , if i jump the starter it will run for 5 to 10 seconds then die , the only code i have is po1629 can some one please help , i want to drive my car ...... thanks
Old Apr 25, 2005 | 07:54 AM
ALZ28's Avatar
Re: Need help with code po1629
What year is car? For a 99 code 1626 is the theft deterrent system which cuts off the fuel at the PCM if the correct key is not used,there are 15 different codes(resistances) for this year.Or it could be faulty sensor/wiring connections in the ignition barrel.You need to check resistance across key contacts with an ohmeter then with key in ignition rotate checking resistance across each position,if there is a 5ohm or over change there is a problem with the key contacts or the lock cylinder.
Sorry can't help any more as this is the only info in my manual
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
