ABS tied to the PCM?
Re: ABS tied to the PCM?
The ABS is controlled by the Electronic Brake Control Module (EBCM). There is a tie-in the PCM only in the case of cars with ABS and TCS.
Courtesy of Shoebox:
http://shbox.com/1/ABS_schematic.jpg
When I first start my car, it runs with no abs inop light, after maybe one minute it will pop on for no reason, before I even put it in gear. Is there a trace program you can use to find the sensor/problem??
Nayr
Mar 3, 2023 08:34 PM
