Best LT-1 N2O cam?
Old Jun 20, 2003 | 11:10 AM
indy500ss's Avatar
Best LT-1 N2O cam?
Okay I am about to buy myself a N2o setup, with all the bells and whistles. I want to run nothing bigger than a 150 shot. I currently have a 222/232 cam in the car, but I am looking for a cam that will be more benificial on gas and off gas. The bottom end is stock, but I have forged pistons.
Old Jun 20, 2003 | 11:23 AM
HungryT/A's Avatar
Hey Indy,
Check out Combination Motorsports LT1 nitrous grinds. They're Comp XE's, folks get good results with them.
Old Jun 20, 2003 | 11:31 AM
indy500ss's Avatar
I only plan on using the gas for the track, I want a powerfull cam for the street, but will still benifit me when I shoot up!
Old Jun 21, 2003 | 07:06 PM
Geoff Chadwick's Avatar
I choose a 218/230 114LSA XE grind w/ 1.6rr cam myself, on *mild self port* heads and intake. I couldnt give you a dyno before, or after yet, but I can tell you, when tuned, it is certainly a nice cam. It dosent gurgle at idle, but it does pound a bit. You can tell the car has a cam in it. But on low end, you loose a tiny tiny bit at part throttle and under 1200rpm, but not much. But at WOT at even 1500rpm, the car howls foreward. Problem: Because of the 114 lsa, a similar cam on a 112 will have additional power, but it is a blower/nitrous cam, so you want the greater lsa.
Otherwise, with the proper valvetrain (talk to cmotorsports) the car runs like a champ. I've seen no lack in power, and my gas milage hasnt dropped an ounce, if you care. I still have the stock gears of 3.42 in my 6spd, and honestly, it would benefit taller ones, but I'm not going that route yet.
Great cam for sure!
Sergio
Jan 27, 2016 04:27 PM
kksi
Feb 16, 2015 06:49 PM
Jlo
Feb 3, 2015 09:41 PM
sskevinm
Dec 18, 2014 11:16 AM
taner
Aug 23, 2002 05:25 PM
