FPSS cause surging?????
Old Jun 15, 2003 | 02:43 PM
snksknr94's Avatar
I've had several people tell me that a fpss will cause surging and not to use one. What does the surge feel like? I think I'm going to still run the fpss, but I would like to know what to be on the look out for.
Old Jun 15, 2003 | 04:18 PM
LPEdave's Avatar
If you hook up a FPSS wrong, you can cause the surging your friends are mentioning. It will feel like you're flipping the nitrous on and off, and will be very obvious. Rather than not using one, I'd suggest not hooking it up wrong
Dave
Old Jun 15, 2003 | 05:38 PM
Hawk's Avatar
i had surging problems. No matter how u hook it up unless u crank it down to like 25psi there will always be a SLIGHT surge because pressure will drop when the noid opens if u T it in b4 the fuel noid. Unless u hook up the FPSS up close to the pump and not the noid, but that would be a PITA. I pulled out my FPSS and replaced it with a FP guage. The surge isn't THAT bad, but IMO i don't like ANY surge, i want 100% clean hit.
Old Jun 15, 2003 | 07:21 PM
sideways_Into_3rd's Avatar
i have no surging problems .. though i run a walbro 255 intank
i think anyone running nitrous should upgrade their fuel pump
Old Jun 15, 2003 | 10:08 PM
funina91ss's Avatar
Dave
What would be the wrong way??? you just take the activation wire and run it inline with it right
_______O________ <------like that
Old Jun 15, 2003 | 10:37 PM
LPEdave's Avatar
Yep, but lots of folks have it cut off the fuel solenoid as well as nitrous. You only want it to cut the nitrous solenoid.
Dave
Old Jun 15, 2003 | 10:42 PM
funina91ss's Avatar
the meaning behind it is to let the fuel pump catch up with the flow right. so It will actually shut the N20 off but still be flowing fuel . then when the pressure goes back above 35 psi it will turn on the N20 noid. I have a 255 lph and you can watch the fuel drop this happens really fast. you caint see where it drops to but the neddle moves .I do have it hooked up wrong. mine cuts off both
Old Jun 15, 2003 | 10:45 PM
Black Cloud's Avatar
My switch came with no instructions.How do you adjust it?
Thanks,BC
Old Jun 16, 2003 | 11:52 AM
Hawk's Avatar
LPEdave is right. That would run BETTER then having it turn off both noids. HOWEVER, even in this setup the nitrous will kick on for a second, turn off for a split second, then hit again and stay on. Some ppl may not notice it, but i do. It's because soon as the fuel noid opens, pressure drops, the nitrous noid is cut off, then the fuel pump catches up and then your set. But u still have that split second where fuel is going in and the nitrous noid gets cut. For safety, run it, for a 100% clean hit, don't
Old Jun 16, 2003 | 11:56 AM
WS6_Keith's Avatar
Dave's on the money. Also, make sure you mount the FPSS as close to the rail and as far from the solenoid as possible. This way, pressure drop at the solenoid won't affect the FPSS as much as you have more volume at the rail.
Old Jun 16, 2003 | 06:45 PM
MARSTAUT's Avatar
what if you adjust the cut off setting higher?
truecontr3
Oct 11, 2015 09:30 AM
grgguy
17
Feb 23, 2015 07:57 PM
Hawk
N2O Tech
11
Jan 25, 2003 11:38 AM
Hawk
N2O Tech
Jan 10, 2003 02:01 AM
LT1S10
N2O Tech
Jun 28, 2002 06:42 AM
