LT1 Nitrous gurus inside, need jetting size.
Old May 28, 2003 | 05:48 PM
JucinGTA's Avatar
A LT1 with Headers and msd 6al box. What should I use for a 175 wet shot? Jetting wise. Stock Injectors too.
Old May 29, 2003 | 04:30 AM
94DROPTOPZ28's Avatar
For a 175 shot I'm using a 76/Nitrous & a 38/Fuel but thats with a Nitrous Works wet-kit
Old May 29, 2003 | 08:29 PM
Tofus 93Z28's Avatar
n20 jet
for my 175 im using 76 and 33... i have an stock fuel pump and an extra pusher... WOT fp is 52-54, NA motor runs 12.5:1 A/F, around 12:1 A/F with said jets...
you really have to be consevative until you do some tuning and checking the plugs...
thats on a TNW plate...(the nitrous works)
Old Jun 6, 2004 | 02:00 AM
Revis_Racing's Avatar
Barry Grant Jetting Table says 70, 33 for a 175 shot.
What bottle/fuel psi are you guys running?
Old Jun 6, 2004 | 11:15 AM
rskrause's Avatar
Moderator
http://web.camaross.com/forums/showt...&highlight=jet
Read the whole thread and pay special attention to the cautionary statements.
Rich Krause
Old Jun 6, 2004 | 12:55 PM
OK, so single nozzle setups and tb LT1 plate setups are totally different on the jetting?
Old Jun 6, 2004 | 01:03 PM
What I have done is removed my nos 5176 dry setup, and am converting it over to a nitrous works plate using my nos solenoids.
I've never used a wet kit before. What jetting is correct for the following shots on the nitrous works plate setup: 50-75-100-125-150.
Note: I currently have a rich running car (11.4:1afr) so would that effect my jetting? I want the afr to be about 12.5:1
MadMav
May 25, 2015 09:35 PM
Jrlt1
Jan 3, 2015 07:38 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
