Help with nitrous set-up
Old Jun 11, 2003 | 11:43 PM
Jcb890's Avatar
I am trying to acquire the parts i need to run a NX wet kit 100 shot. here is a list of parts i have come up with:
- LT1/ LS1 Nitrous Express 50-75-100-150hp Adjustable Kit
- GEN-X2 upgrade
- 8.5MM SUPERCONDUCTOR WIRES
- MSD 6AL IGNTION BOX - with revlimiter
- NGKTR6 plugs
- MSD Window Switch
- RPM PILLS
now is that what i need? should i get nething else? is there nething on this list that i dont need? like if i get the MSD 6AL do i need the Window Switch? if i just get the window switch do i need the MSD 6AL i would think if the window switch makes it run between certain RPMs i wudnt need that revlimiter...if this idea works, then do i even need an ignition box? please help guys. im trying to get the best nitrous set-up i can for the least amount of money as possible. any help would b appreciated.
thanx,
jake
Old Jun 12, 2003 | 03:55 AM
sssalah's Avatar
Why not get the Malory VI 685, its a digital CD ignition with built-in rpm limiters, timing retard and a window switch no pills needed here. This is basically has all the features of MSD digital 6+ with the addition of a window switch.
Old Jun 12, 2003 | 11:40 AM
Jcb890's Avatar
where can i find malory things? most sites i've been using do not show any Malory products.
Old Jun 12, 2003 | 11:42 AM
JSK333's Avatar
www.summitracing.com sells Mallory. It's made by the same company that sells Accel (Mr. Gasket).
Old Jun 12, 2003 | 11:49 AM
Jcb890's Avatar
Does this list I made seem good? what's the part number for the Malory VI 685?
Old Jun 12, 2003 | 03:44 PM
sssalah's Avatar
Summit has it under P# (MAA-685) for $225 and JEGS under P# (650685) for $220. Don't forget to get the harnees for your car it makes it much easier.
Old Jun 12, 2003 | 08:17 PM
Jcb890's Avatar
so if i get the Mallory i wouldn't have to get the MSD 6AL IGNTION BOX - with revlimiter, MSD Window Switch, or RPM PILLS? is this assumption correct?
Old Jun 13, 2003 | 12:45 PM
sssalah's Avatar
Yes, plus it features an adjustable timing retard, very usefull for n2o.
Old Jun 13, 2003 | 02:09 PM
JSK333's Avatar
Is the timing retard tied into the window switch I assume? Maybe I should "upgrade" to this from my Accel 300+ & Mallory window-switch, since I need timing retard too.
Old Jun 13, 2003 | 02:44 PM
Hawk's Avatar
u already have the window switch and ignition, i'd just buy the accel timing retard module, it hooks up to your 300+ and will pull back the timing to whatever u want it to pull back. It is activated by a input which I'd just tie to the arm switch, thats allu need
www.lingenfelter.com sell them
Old Jun 14, 2003 | 04:06 PM
Jcb890's Avatar
lemme get this straight. the Mallory comes w/ a built-in window switch so i can have my nitrous run from 3000rmp - up and it has everything i need?
i ordered the Kit and the GenX-2 upgrade and the NGK TR6 plugs, then i need new wires and the Mallory ignition...is this all that i need? does ne1 else recommend something else that i should have to run my NX wet kit 100 shot set-up????
thanx,
jake
Old Jun 14, 2003 | 04:40 PM
chevy94c's Avatar
You should be all set for the 100 shot.
Old Jun 14, 2003 | 07:24 PM
Wild1's Avatar
What about the fuel pump? What are you currently running?
Old Jun 14, 2003 | 11:57 PM
Jcb890's Avatar
Im runnin the stock fuel pump.
Old Jun 15, 2003 | 10:53 AM
Jcb890's Avatar
anything else guys? nobody has any other opinions?
thanks for all the help so far,
jake
