Relays in the 5176 dry kit...
Old May 27, 2003 | 11:31 PM
roguedriver's Avatar
So why is there two relays in the 5167 dry kits? Just wondering. Thanks.
Ken R 95Z
Old May 28, 2003 | 04:30 AM
transamtom's Avatar
One is for the inline fuel pump,the other is for the solenoids.
Old May 28, 2003 | 08:42 AM
Ok, but....
Ok, if it's for the solenoids, then why doesn't it show it wired up in the instructions? It just shows the solenoids wired together without the relay. Thats why I was wondering. So why would you use the relay with the solenoids? Thanks
Old May 28, 2003 | 09:31 AM
BILLJ's Avatar
The solenoids draw more curent then the arming or WOT switch can handle. The switches would kinda melt. Same reason there are solenoids that are built into the starter. They alow you to switch the high curent with very little switches and curent draw.
Old May 28, 2003 | 10:58 AM
snow2000SS's Avatar
One is for the pump and one is for the solenoids. It doesn't show the relay hooking up to the solenoids becuase there is missprint in the instructions it shows the wiring for like a typical plate system.
Aaront810
Aug 29, 2020 09:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
Boss002
Jul 24, 2015 10:47 AM
