Nitrous Switch Questions, Do I have the right ones?
Gathering up switches for the nitrous install and wondering if these will be right for a full nx install.
arm: on-off
Purge: (mom) On-Off
bottle opener: (Mom) On-Off (Mom) is that correct?
Bottle Opener: I can wire this up to a relay to come on with the ignition correct since it is pressure switched?
thats all i should need right for switches besides the other safety ones, Wot, window, etc.
arm: on-off
Purge: (mom) On-Off
For the bottle open light, you could do a latching relay, (and a second, to turn it off) to create a circuit, that will light up when you "open" the bottle, and wire it to the "open", and "closed" sides of your switches, i can draw up a diagram if necessary, but it will be complicated, and will not be 100% to tell if open or closed. it will just light "open" when the switch was on the "open" side last, and if switch is pushed closed, will turn off, (but bottle could still be partialy)
For the opener switch, you need a DPDT switch, momentary, wired to reverse the polarity of the bottle opener.
Ryan.
Ryan.
if what im thinking will work, it will turn on a light whenever you "open" the bottle, and turn the light off, when the "close" side of the switch is pressed.
Give me a couple days, and i will draw it up, and test it out, before sending you a finished schematic.
Ryan.
Ryan.
