Powder Coating your bottle
Old May 14, 2003 | 01:38 AM
TCAL95Z's Avatar
I'm buying a used kit and the bottle is a little scratched up.
Is there any problem with having the bottle re powder coated?
Also, do most bottles get scratched when they are taken out to be filled? Which brackets can I buy to stop this?
Tom
Old May 14, 2003 | 10:55 AM
Fuels94TA's Avatar
Yes you can get the bottle coated, but your going to remove the valve assy. so they can do the job right. After that your going to need to get the bottle certification and pressure tested. Another way to prevent you from taking the valve assy. out is. Prep the bottle and do it by spary painting and then a nice clear coat finish. Which I did on my bottle, yes your bottle will always get scratched up from taking it in/out the bracket and giving it to the refill station. What I did on my brackets was install rubber gaskets on the metal brackets which helps somewhat. Then if your picky about giving it to someone to refill have a rag/towel wrap around it.
Vinny
Old May 14, 2003 | 11:06 AM
Might be worth a little research before you powder coat. As I understand it, powder coating requires heating the item to about 400degF in an oven. Not sure what the affect would be on the strrength of the aluminum bottle. I know there was a huge flap a few years ago when cracks started appearing at the neck of certain aluminum 3AL bottle that were used by divers.
I'm not saying there is definitely a problem.... just that the conservative "injuneer" in me is saying check first.
Old May 14, 2003 | 03:17 PM
chesee48's Avatar
You could also polish it i believe.
Old May 19, 2003 | 01:40 AM
TCAL95Z's Avatar
anyone else?
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
blaze309
Sep 8, 2015 05:27 PM
KYWes
Aug 10, 2015 07:03 PM
