bottle heater thermostat
i bought a bottle heater off a guy and it doesnt have the t-stat. can i run it without it? or can i buy one of these somewhere? if i can run without it, what do i do with that wire that is for it on the relay? thanks
I had all sorts of NOS tstat's for thier heater,and IMO they are all junk.
Smart thing is to use a Tstat,but since Nitrous Express runs at a higher bottle pressure then NOS<my setup is better suited for NO tstat and watching the pressure guage.
i think i am going to run no stat and just get a gauge and watch it. the wire that i am talking about is just one off of the relay. should i just run it to nothing? or just ixnay the relay itself? i'm not too swift on the whole wiring thing..
I would think if your not running a pressure transducer you wouldn't even need the relay. The whole reason for the relay is to turn off the heater when it get to the right pressure. If you have nothing measuring the pressure then relay will never be able to turn anything off.
yeah, RUN A RELAY. A relay is there so that a small current device like your switch can trigger the bottle heater to get a direct connection to the battery and draw as much current as it needs. Make sure u use correct guage wires too, and solder your connections.
