Are all TNT LT1 plates 58mm??? (will this disrupt airflow?)
Old Jun 14, 2003 | 02:06 PM
U Can't Z Me's Avatar
Hey guys,
Are all the TNT plates for LT1 58mm???
Will this hurt airflow...I have the stock 48mm Throrttle body, 58mm TNT plate, and stock 52mm openings on the intake? Is the 48-58-52 gonna screw up airflow or is everyones TNT set-up that way?
Should I make the openings on the intake 58mm?
If I leave it , what size gaskets should I use?
Let me know.
Thanks,
Eric
Old Jun 14, 2003 | 08:56 PM
Dan Parker '96's Avatar
Yes, all the TNT plates are 58mm (and you'll need to drill/shape the IAC opening on the plate as it is entirely inadequate).
The stock TB gasket is 52mm so it'll match up (size-wise) with the holes on the intake. You'll need two gaskets naturally.
Lastly, NO the discrepancy in the bore sizes between throttle body, TNT plate, and intake bores won't be a problem at all.
Old Jun 14, 2003 | 09:53 PM
ok cool, thanks for the info.
Do you have any pics of the IAC opening after you drilled it?
thanks,
Eric
Old Jun 15, 2003 | 04:37 AM
Here's a link to another thread that has a pic of the uncompleted plate drilling (one of my posts). Scroll down a bit. The post explains the pic.
http://web.camaross.com/forums/showt...hreadid=130357
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
ddr698
Jan 9, 2015 10:05 AM
heavenly_six
Dec 10, 2014 12:23 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
