What do I need?
Old May 11, 2003 | 09:35 PM
Jcb890's Avatar
What do I need?
hey guys,
as u can see in my sig, my car is totally stock. '95 A4 Z28 122,xxx. i only need it to really last me till fall cuz i go to college and then ill store it then when i get out i wanna do an engine rebuild...that being said...
i was looking at a NX WET KIT 100 shot. ive heard this is good and is very popular w/ the LT1 guys. ne1 got ne bad comments about this kit? i was going to try and get a GP going to get this kit, but i dont know exacly what i need...i want all the safety stuff. what do i need (part #s if possible) for the actual kit w/ nozzles and stuff, purging, guages, opener, heater, etc...i want it all, dont wanna half-*** it. also, what do i need for plugs, wires, ignition, programming, etc...i need some help guys, all help will b much appreciated. i wud not put on the kit b4 i saved up more after getting it to get intake, headers, and cat-back at the least.
thanx a lot in advance 4 the help.
jake
Old May 12, 2003 | 04:09 PM
Jcb890's Avatar
oh yeah, about how much will this whole thing cost me?
jake
Old May 12, 2003 | 06:09 PM
stik6shift98's Avatar
about 850
Old May 12, 2003 | 08:45 PM
Jcb890's Avatar
stick6shift...think u can help me out and maybe tell me what i need? i cud have pulled a random # outta my @$$ and told sum1 that too, but instead id rather give them some help. i u can help me, then plz do, if not, then dont bother posting. if there is a place where i can get the kit and every safety thing i need and stuff for $850, then i wud like to know cuz i dont think such a place exsists...
jake
Old May 12, 2003 | 08:48 PM
Jcb890's Avatar
Also, do i really need the GenX2 upgrade and what is the benefit to having it?
thanx,
jake
Old May 12, 2003 | 09:37 PM
sniffin94's Avatar
buy the stock kit. you really don't need the upgrade kit. You will probably want a bottle heater and a purge. With an automatic you really don't need a window switch. You will need to buy NGKTR64177 plugs gapped at .35. I run msd wires and a msd 6Al ignition box. I don't have a fuel pressure safety switch you really don't need one. I spray a 175 shot through a stock motor. If you need anymore help let me know. You should be able to get everything for around 750.00
Old May 13, 2003 | 12:31 AM
Jcb890's Avatar
i like the sound of $750 for the whole package...is that including a new MSD 6AL or something similar w/ new NGK plugs and wires? that sounds nice, where do u suggest i look for the best prices? thanx man. anyone else have any input about this whole thing and especially about the Gen2X upgrade?
thanx every1,
jake
Old May 13, 2003 | 07:32 AM
sniffin94's Avatar
the basic nitrous kit should run 500. msd 6al box 150, wires 60 and plugs 20. Thats around 750 there but of course there's shipping and stuff. All the genx upgrade kit is is a bottle heater, purge, gauge, fuel pressure safety switch, and a blow down tube. If you have the money right away then get it but none of the stuff in there is really necessary to run your kit right away
Old May 13, 2003 | 03:31 PM
Jcb890's Avatar
i figured more guys would chime in on this and help me out. come on guys where r u all at? i know u know ur stuff and i need some help. some descriptions of what u guys have 4 set-ups wud help a lot too.
thanx,
jake
Old May 14, 2003 | 10:28 AM
Jcb890's Avatar
comon guys, i need some advice here....
Old May 15, 2003 | 08:48 AM
tbyrne's Avatar
Here is the basics that I would go with -
20920-10
LS1 Nitrous Express with 10# bottle 50-75-100-150hp Adjustable Kit
$559.99
15509_
Nitrous Express Nitrous Pressure Gauge 0-1500psi
$44.99 - always good to know your bottle pressure. For best performance it should be in the 900-1050 psi range.
15607_
Nitrous Express Filter and stainless steel hose
$49.99 - like any other filter - very important.
15940
NX bottle warmer
$199.99 - If your in a warm climate you may be able to get away without this for the summer but it helps maintain your bottle temp/pressure.
NGK TR6 plugs - these are one heat range colder than stock and gapped at .035 - Recommended for nitrous or supercharged motors
$2.29 each
6200_
MSD 6A Ignition Control
$189.99
$1063.27.
Take out the bottle warmer and that would bring the total down to $863.28 and there is a $50. discount this week on the kit - $813.28 and if you order the rest of the items online that will save you another $15. to get the total under $800. It just depends on which accessories you would really like to go with.
Tom
Old May 15, 2003 | 12:26 PM
Jcb890's Avatar
thanx a lot tom, ill have to get back to u on that.
jake
