Dry vs. Wet?? and a couple other ?'s
Old May 12, 2003 | 08:33 PM
torched's Avatar
I am looking for a nitrous set up to run on my '95 Corvette A4. The car is all stock, with the exception mufflers, and will have other minor bolt ons in the near future. I don't plan on spraying much, just want a little extra power when in need. What would be the best kit to go with a 75 shot, wet, dry?? and maybe those occasional 100, 125 shots
I probaby won't run a 100+ shot without replacing the fuel pump, to be on the safe side. I'll also need to replace the spark plugs with some ngk tr6's (or any good n2o plug), correct?
It'll be pilled to cut off before the shifts, so will I have any problems banging the rev limiter? Will i need any kind of tuning with the small shot? Any other helpful info would be appreciated. Thanks.
Old May 13, 2003 | 12:07 PM
torched's Avatar
ttt
Old May 13, 2003 | 02:16 PM
qwick_trip's Avatar
well if you want to run a 75 shot and maybe adjust it up then you will want to go with the nx wet kit. the dry kit is adjustable but not very easily. go with the nx wet kit.
Old May 13, 2003 | 05:46 PM
torched's Avatar
which nx wet kit?? please give me the model, because half the time i get confused between the different ones.
ttt
Old May 13, 2003 | 10:33 PM
qwick_trip's Avatar
i am not sure exactly on the kit number you can go to ls1speed. com they have the kits there for your car. you can call the tech line if you want to make sure. also jegs cares nx you can call them two. jegs number is 1800-345-4545
Old May 14, 2003 | 05:21 PM
torched's Avatar
anyone else??
Old May 14, 2003 | 08:50 PM
SVT Killer LV's Avatar
Go with a NX GM EFI kit, Jegs, LS1 Speed, and most other online vendors carry it...
Old May 15, 2003 | 03:36 PM
mike 1978's Avatar
i know the guys here are very knowledgeable, but you want want to check out corvetteforum.com
Jeff1904
Jun 5, 2016 05:00 PM
4586
Sep 27, 2015 01:55 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
NewsBot
Jul 29, 2015 08:10 PM
Boss002
Jul 24, 2015 10:47 AM
