Gains spraying with ported heads?
I have heard that you won't gain as much on spray if you have ported and polished heads. What are some of you heads/cam guys running n/a then on spray?
Aight thats what I thought but friends around here said it will hurt but i just said they didnt have the true hp settings as what they thought or something.. So i guess i was right
thanks
thanks
thanks
thanks
Something really wrong with his car.
These are 1/8th mile times, but NA with top half build I ran 8.00 @ 88mph. On the nitrous 150shot I ran 7.30 @ 98 mph. I was granny shifting and with that mph it could be 7.1 area. So something is really wrong with his car when I could outrun him on a 150shot.
The more EFFICIENT your engine is, N/A... the LESS N2O will help it.
Case in point: Stock lt1's - ls1's usually lose a second of ET and gain 10 MPH on a 100 shot. These engines are on the LOW end of effiency!
Add the same 100 HP shot to a Pro/Stock car and he MAY lose a tenth and gain 1 MPH. Very efficient engine!
Gas helps the weak much more than the strong. A good port job head is stronger, more efficient than a stock head. As mentioned previously, a ported head isn't going to hurt, but that money may be spent wiser elsewhere!
The main benefit of N2O is a heavier Oxygen charge than
Normal Aspiration can provide. THAT is why you have to add the extra fuel... MORE OXYGEN.
Just my HUMBLE OPINION as I am NO EXPERT!!
this will all settle when i go on the dyno within a week ..
my heads flow a humble humble 301/227 @ .600 and i got a tiny 230/244 cam
i'll spray the 100 shot NX wet on the dyno and see if it'll produce 100 rwhp or not !
(not to be biased .. but looks like my heads and cam would love some nitrous thrown at them .. their both exhaust happy
ps. i think what redbird might fail to keep in mind is that .. a 100 hp shot of nitrous will still net the pro stock motor an extra 100 hp .. but that is a small fraction of the total hp .. and when ur in the 6s and 7s 100 hp wont help u as much as it did when u were in the 13s and 12s .. the nitrous is just as efficient on high hp motors .. its just that the extra hp doesnt net as much ET or MPH cuz ur already going so damn fast !
i'll spray the 100 shot NX wet on the dyno and see if it'll produce 100 rwhp or not ! (not to be biased .. but looks like my heads and cam would love some nitrous thrown at them .. their both exhaust happy
)ps. i think what redbird might fail to keep in mind is that .. a 100 hp shot of nitrous will still net the pro stock motor an extra 100 hp .. but that is a small fraction of the total hp .. and when ur in the 6s and 7s 100 hp wont help u as much as it did when u were in the 13s and 12s .. the nitrous is just as efficient on high hp motors .. its just that the extra hp doesnt net as much ET or MPH cuz ur already going so damn fast !
Okay... maybe my Pro/Stock comparison is TOO much.
Let me just say that a 14 second car WILL benefit from a 100 shot more than a 12 second car will. The 12 second car is already making more efficient use of N/A air than the 14 second car, i.e.,
cam, headers/exhaust, CAI, etc...!
An engine, being an air pump, can only pump as much air as it can move in, fire, and push out. The more efficient use of natures air requires less of the bottles air to fill the cylinder. Remember... you can only put so much air, be it compressed or not, into a cylinder before further mods need be done to increase cylinder capacity.
HInk (I think)
HInk (I think)
