Iceman solenoid queston?
Old Jun 7, 2003 | 07:58 AM
sssalah's Avatar
Does the Iceman solenoid come standard with the 20920 kit. What are the advantages of the Iceman compared with the regular stage 1 ‘noids.
I’m ordering this kit along with a genx2, filter kit, and Mallory hyfire ignition, and not sure if there is any advantage other than the orifice size.
Old Jun 7, 2003 | 09:09 AM
red's Avatar
red
The larger orific size on the Iceman selenoid allows for larger HP settings.
Old Jun 7, 2003 | 11:17 AM
sssalah's Avatar
Yes, it has a 0.093 and the stage one is 0.063. Is it standard with the 20920 kit?
Old Jun 7, 2003 | 10:38 PM
CustomN2O's Avatar
Yes, the iceman .093 is standard on that kit. The only difference between an Iceman solenoid, and a regular solenoid, is the purge port built into it. If you have 2 stage 6 solenoids, and 1 is an iceman, it will have a second 1/8 pipe threaded port on the side. No performance advantage, other then allowing liquid nitrous to be present right at the orifice.
HectorM52
Jul 30, 2017 11:46 AM
marlar98
Sep 19, 2015 07:53 AM
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
