question about when to turn the nitrous on
Old May 19, 2003 | 12:10 AM
TMDZ28's Avatar
i would like to know, is it safe, if i floor my gas pedal(WOT) before turning on the nitrous??? or after i go to WOT, then in the middle i just turn it on?? thanks
Old May 19, 2003 | 01:09 AM
TriPinTaZ's Avatar
i used to arm the Nitrous and then kinda roll out of the light at 75% throttle and soon as i got to about 2500 RPM or i got tractio i would drop it to the floor and hang on!
Some do not recomend using the Nitrous until after 3000 RPMs tho. However I never waited that long myself
Old May 19, 2003 | 02:04 AM
TMDZ28's Avatar
because according to fast and the furious you can turn on the nitrous after you floor your gas pedal...thanks
Old May 19, 2003 | 02:15 PM
TriPinTaZ's Avatar
fast and the furious is the biggest load of CRAP ever made
Old May 20, 2003 | 10:56 AM
tweetybirdy's Avatar
You can't say that the fast and the furious is the worst movie......simply because they made a second one..surely it will top the first
Old May 20, 2003 | 03:53 PM
TriPinTaZ's Avatar
I never said it was the worst movie. I just said it was a load of crap.
Example: YOu flip the Nitrous on and it smacks you back into the seat so hard and your face starts to look like you have 8 G's pullin it flat = CRAP!
Purple/ Blue exhaust flames when stepping on the gas= CRAP
that must be propane, not to mention i belive the flames of race cars from the tail pipe happen after rapid DECELERATION ( letting off the gas quickly)
A LAPTOP that tells you after running Nitrous for a full 45 seconds your manifold is in danger???? Uhhh I think the pistons would melt first, not to mention you would be doing alot more than 130 MPH.
Oh and when the engine breaks on the green car ( undercover cops car, part one) I doubt your going to see a floor board fall off and misc washers and bolts go flying. Then the engine is smoking like a burnt steak. then a few minutes later he racing the same fried engine and it runs perfectly fine.
HaHaha damn Ricers!
Heres waht i think of fast and furious part 1 AND part 2
http://very.de/
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
formula79
26
Aug 5, 2002 12:21 PM
